Sidehop?
Hey well i've been reading that you should learn to sidehop oppisite to your lead foot because you can catch your pedal, untill i read this i could sidehop fine to the right and im right footed.
Now i have been trying to teach meself to sidehop left but can only do 35 inchs but i go the front wheel and swing the back end round which is really uncomftable and feels wrong and my balence is all out. However if i sidehop to the right then i can get 40 inchs and land flat.
So is it worth pushing myself to sidehop left?
Cheers
Adam
Cheers
Adam
technically its better to sidehop opposite as like you say your pedal is in the way. but watever is comfy really just keep doing it the way you like and try opposite to push yourself. as you probably seen neil tunnicliffe can get rather high and he sidehops "the wrong way".
im right footed and i sidehop to the left. it does feel alot better goin the opposite way but like the guy above said neil t goes the same way as his lead foot, so obviously you can go which ever way feels best.
cheers lou.
It is also better if you don't fully make the sidehop because you drop down to your crank then your balenced.
Matt Rushton
dunno bout you but I got cranks on both sides of my bike ;)B)
Ive found sidehopping to my left more natura now because Ive done it so much. I cant really push myself when I go to the right, i have a "set" height although I've found from two wheels to two wheels is much more fun to the right :D
I learnt to sidehop to my right first, then only a couple of years ago decided to learn to my left (right footed)
now it feels better going to the left, as you can get closer to the obstacle and "tuck" better
hope this helps. best to learn both sides of course!
Well i am left footed and i feel realiy un comfortably when i try to side hope right i have found it eaiser to side hope left.
Its like most people have said neil.t side hopes right and gets high and he uses his right foot.
Use which is eaiser for you.
Lee.
he actually side hops to the left...
using his left foot....
I have also got 2 cranks but you don't drop down onto both thats why I said "crank" not cranks.
Matt Rushton
Cheers
Adam
Yes it defently is worth pushing your self to do it to the left just a couple of weeks ago i was likeyou and felt all uncomftable going to the left but know it feals normal and i can get about 7 inches higher than i could before.Just keep practasing what i did to get used to the feal because it realy is a strange fealing is just do it on a little wall that u can do until you feal comftable it helps.Good luck.
Sam
yep i was in the same boat as you...i was a right footed man sidehoping to my right.....was getting around the 40 inch mark......decided i had way to many bad falls on my arse ......so i started going 2 the left.......now i feel my level of riding has inproved in all ways........
i do have a tip for you to help with landing to 2 wheels instead of the front first.........
it works for me anyway hear we goeth........
once on your rear wheel hold the balance for as long as you can and jump straight up....keeping your eyes on top of the wall u wish 2 sidehop...push your arms way out in front of you just before you land.........job done 2 wheels on top of wall at the same time
good luck hope this helps
and good luck with the sidehops dude (Y)
Matt Rushton
yes but youre implying you only drop to crank on one side... otherwise why state the obvious
meh nm
Edited by PaRtZ
The worlds best riders tend to be able to sidehop high to both sides so its good to try to both sides, im left footed an sidehop to the left higher an more comfortable but try to the right aswell. i really hate it when people say you have to sidehop to the left if your right footed an vice-versa, like everyones been saying just look at the way nezza sidehops left/left (Y) . Ben G WST
I have to agree with that!! I'm just learning to side hop to my back foot side. This is because when you do it to the front foot side, and miss, there's nothing but your arse to hit. The other way (as other people have posted) you can drop to the crank if it doesn't go to plan. keep hucking at it.
erm.. cant you drop to the crank if you side hop the 'wrong' way also, im sure people normally ride with two.
If you think of how your bosy is designed... when you side hop to the left with your right foot forward, it is much easier to get tuck, because of the way your legs are positioned... they are in the right position to get alot of tuck...
also when you gap... if you gap right foot forward, you should gap to the left (take off at a angle to the left...) this is because your body is designed to stretch alot easier the way your feet as placed. if you gap right foot forward are to the right, you are stretching your left leg alot and you dont get full extrention of your body in mid taking off point...
If you get what i mean :D
In other words.. im perfect. walk on water n stuff.
