19" Rim Choices? Other Than Deng & Tryall Etc.
eskimo
Am looking into using a different for a change. As i know they're some really good ones besides the anodized world.
The rim needs to be strong as per usual but doesn't need to hold a heavy grind as i probably won't grind anyway. Looking for 32h which does limit me slightly.
Just to check i will be building my echo fixed hub 07 onto whichever rim. It is the larger flange one. So for 32h am i going to need 186 or 184 spokes. I'm pretty sure 184 will be fine as i will be using longer nipples anyway.
Thanks in advance for serious imput. If anyone mentions rims that are listed on Tarty i won't be happy.
i heard the kris holm rim was good, if your building it nick.. could u not just miss out for spokes... at each point...top bottom side side!
if not get a 07 echo rim! you girl. :)
Nah i don't tend to be a bodger anymore. Plus i intend to use expensive spokes.
And i just wanted something different, something that hasn't got holes in it.
[edit]
you got the link for that magnalium thing?
Edited by eskimo
