Woodman Elite
Phreemann
Went for the Ryan Leech, old-skool style bike as I use this for a bit of everything, from just getting around to street, jumping, and trials. Also because I used to ride a lot more some years back, and wanted to build up with the parts I wanted then now that I've got some money.
Yes, I have vertical dropouts and no tensioner. ZOMG!!! I hit lucky with 'magic' gearing, a fairly old pre-stretched chain and a half-link piece, perfect chain tension. Geared 32:18 currently - high for trials, kinda low for everything else. This bike is all about compromise.
But it works! I love it - the way it rides, handles, everything.
Spec;
Woodman Elite frame
'03 Marzocchi MX Comp forks
Hope O2 front brake, Pro lever, Leeson 185 trials rotor
Magura HS33 '05 rear brake, 4 bolt Gu booster, Snowy pads, water bleed
DMR Saturn chainring, 4-Jeri 3-piece cranks, knockoff V-8 pedals
24Seven Supercross wheelset
Maxxis Holy Roller 2.4 tyres
Azonic Hot Seat, Ritchey short seatpost
Azonic World Force bar and stem
ODI BMX Ruffian lock-on grips
A2Z singlespeed conversion
Let me know what you make of it. ;)
Nice little street bike you have got there, I know that GU booster form somewhere! lol
Is she light?
Heh, yeah, that Gu booster with the brake is lovely - once it's on! I don't think anyone knows what a bitch Magura's are to fit until they try. I certainly didn't. I have a feeling it'd be easier with no booster and normal length bolts, but where's the fun in that? ;)
It used to be light, for what it is - with a rear disc, no front brake and slightly lighter wheels it weighed 25.4lb, but I haven't weighed it since changing quite a lot. It's heavier now, but not by all that much. It's certainly no "heavyweight" bike.
Looks luuush! Just needs a phat rotor and disk on the back and it'd be one sexy piece of bike.
Had a Hayes HFX-9 on the back.... Didn't like it. Not enough grab and hold for me. I'm digging the Maggie at the minute; damn they're noisy when they're wet! I think I just annoyed half my neighbourhood. I'd try another Hope O2 Pro with another Leeson rotor on the back, to match the front, but I don't have the cash, and I'm still not convinced it'd be enough.
Thanks for the kind words so far people!
Edited by Phreemann
Almost all the trials riders in my area ride those frames! Heavy as anything, but they like them. Looks like you'll get on with it good.
4.6lb is heavy? :blink:
I didn't think it was too bad? Seemed light for street frame anyway, at least compared to the steel alternatives.
You've got me thinking now. I've no idea what trials frames weigh. What would people say is the average weight for a trials frame?
One of my buddy's has one of those frames and it is heavy! It might be a steel version though. It definitely wasn't 4.6 pounds though! He was also running rear discs too. 4.7 pounds for the Adamant A3 and that's a mod! I think you might have weighed it wrong cause that is unbelievably light! I ride an Onza T-Rex and it was tons lighter than the Woodman. The Onza's not supposed to be light either though.
Mine's very light, I didn't weigh it as a frameset but it really did seem silly light when I was carrying it back from the shop. The Woodman website lists it as 2100 grams:
http://www.woodmancomponents.com/catalog/c...fra&lang=en
Some swift conversion courtesy of Google confirms this as 4.6lb
Is your friend running uber-heavy components or something?
Having just done a search, seems that 4.6lb is at the medium-light end of the spectrum; thanks to Component Weights V1.1 by Jang.
Frames
Ashton Justice Frame 3.5 lbs (Mark 1)
Ashton Justice Frame 4 lbs (Mark 2,3)
Base TA 26 - 4.9 lbs
Brisa B26D Frame 4.004 lbs
Coustellier w/o mech hanger 4.45lb
Crescent Ilions 2001 3.96 lbs
Curtis Elite 2002 Frame 4.29 lbs
Curtis T1 Comp Frame 5.08 lbs
Curtis T1 Street Frame 5.19 lbs
DDG Shooter Frame 4.5 lbs
DMR Sidekick Frame 5.5 lbs
Echo ES2 Frame 3.96 lbs
Echo Es3 Frame 4.2 lbs
Echo Es4 Frame 3.4 lbs
Echo Urban 4.5 lbs
GT Chucker Frame 5.5lbs
Identiti Judge Frame 5.1 lbs
Koxx Levelboss 1065 4.95 lbs
Onza T-lite 3.5 lbs
Orange Zero 2002 Frame 4.4 lbs
Pashley 26MHz Frame 4.4 lbs (Also Claimed 4.3 lbs)
Planet X Pitbull Frame 7 lbs
Planet X Zebdi MK 1 Frame 4.75 lbs
Planet X Zebdi Mk 2 Frame 4.5 lbs
Planet X Zebdi MK 3 Frame 4.3 lbs
Planet X Zebdi MK 5 Frame 4.2 lbs
Planet X Zedbi Frame 4.5 lbs
Saracen M-A-D Frame 5 lbs
Saracen X-tort frame (non-oversized stays, seat tube cut down to 12.5") 4.63 lbs
Frames
Echo Urban 4.5 lbs
Onza T-lite 3.5 lbs
That's some good information! All I know that he is running is an Echo fork and front and rear Magura louise. Most of the parts are off of his old Echo Pure. I don't understand why it was so heavy! I rode it and couldn't even bunnyhop very high at all. Maybe it was just my imagination. Although I just
got off my Onza so that might be why his bike felt heavy. But my Onza, is not supposed to be light either.
Edited by J Trials 31
