Ben John-Hynes Posted March 30, 2008 Report Share Posted March 30, 2008 Do Cross Countrs riders who use Maguras use anything on their rim like a grind?If not,how do they get their brakes to grip in the wet?Ben Quote Link to comment Share on other sites More sharing options...
dave85 Posted March 30, 2008 Report Share Posted March 30, 2008 Smooth rims always, some people have ceramic coated rims but never a grind. Maguras develop huge braking force at speed, even in the wet they're more than powerful enough with kool-stop pads. Quote Link to comment Share on other sites More sharing options...
Adam-Griffin Posted March 30, 2008 Report Share Posted March 30, 2008 Don't alot of them use Hydro discs though ? Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted March 30, 2008 Report Share Posted March 30, 2008 i should think they just have a clean rim,as in my experiance maggies have the power but not much hold on smooth wet rims Quote Link to comment Share on other sites More sharing options...
maxwellduryea Posted March 30, 2008 Report Share Posted March 30, 2008 they used to use em, but now almost all brake setups are either uber light v's or discs. Quote Link to comment Share on other sites More sharing options...
dan_addison Posted March 30, 2008 Report Share Posted March 30, 2008 People used to use them, but they where just wank in mud or wet.As for grinded rims i dont think anyone would dare to take a anglegrinder to an expensvie rim. Now its either discs or v's on race bikesPeople used to use them, but they where just wank in mud or wet.As for grinded rims i dont think anyone would dare to take a anglegrinder to an expensvie rim. Now its either discs or v's on race bikes Quote Link to comment Share on other sites More sharing options...
rudirudirudirudirudi Posted March 30, 2008 Report Share Posted March 30, 2008 (edited) what they tend to do for the wet, is file out grouves in the pads.this stops that layer of water getting trapped between pad and rim!!!!. so instead of putting a grind on the rim they effectively do the same thing but in their pads. problem solved. Edited March 30, 2008 by rudoxolty Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted March 30, 2008 Author Report Share Posted March 30, 2008 what they tend to do for the wet, is file out grouves in the pads.this stops that layer of water getting trapped between pad and rim!!!!. so instead of putting a grind on the rim they effectively do the same thing but in their pads. problem solved.Like on the Onza pads?Clever(I) Quote Link to comment Share on other sites More sharing options...
feest Posted March 30, 2008 Report Share Posted March 30, 2008 most super race xc'ers use v brakes but on the whole its hydro discsi had maguras on a few xc bikes but only those without disc mounts Quote Link to comment Share on other sites More sharing options...
Peperami Posted March 30, 2008 Report Share Posted March 30, 2008 You use a grind/ tar to make your wheels lock instantly on a trials bike. You definately dont want your wheels to lock on an xc bike... the gripping power of most brakes is more than enough to slow you down. Quote Link to comment Share on other sites More sharing options...
BenLeacock™ Posted March 30, 2008 Report Share Posted March 30, 2008 Maguras have to much bite for xc really, you need more of a speed reducing brake that has alot of modulation rather than a brake that will lock on if you get what i mean ? Quote Link to comment Share on other sites More sharing options...
ruckus_street Posted March 30, 2008 Report Share Posted March 30, 2008 XC racers in the majority of situations are using discs nowadays (a LOT of suspension forks have only got disc mounts)But in particularly dry situations or if you're a realllll weight weenie, V brakes are usedRarely see hs33s on mountainbikes these days. Quote Link to comment Share on other sites More sharing options...
psycholist Posted March 31, 2008 Report Share Posted March 31, 2008 (edited) I used to use Maguras for XCing. If I had no choice but to run rim brakes I probably would again too. Maguras don't have the power wet or dry that a similarly priced set of V's will have, but they stay working in the worst mud, dirt and slime without me needing to constantly adjust/replace the brake pads, replace the cable, have a grindy brake feel etc. At this stage the only people on Maguras are trials riders and German cycle tourists as far as I can see...For XC use I never ground the rims - the mud provided more than enough grinding without any help. If it was really bad I could wear through a rim in a year just from braking on it. I think I've replaced a trials bike rim once for the same reason in 6 years of having a specific trials bike.Disks are better in every way for XC riding unless you live somewhere very very dry, in which case V's would probably stay working properly... Edited March 31, 2008 by psycholist Quote Link to comment Share on other sites More sharing options...
Muel Posted March 31, 2008 Report Share Posted March 31, 2008 I ran a set of 04 maggies on my XC bike, they were fine for all weathers, even when wet. Quote Link to comment Share on other sites More sharing options...
