Hs33 Levers
jimseyd
I have '04 magura levers and brakes and i was wondering is there any quicker way to adjust for wear than moving the entire pad. I know the current hs33 lever blades have adjust knob, but is that compatible with mine?
God dang. The tpa is gone, bugger. Must have died with the previous owner! Where can i get one and how much do they cost.
PS Does anybody have any opinions on how good they are?
Edited by jimseyd
I bodged mine differently.. no silly looking bolt sticking out! So you can still use the red adjuster.
When you take the lever blade apart, you should have the remains on the 'fork' shaped part of the TPA, then the square looking nut with part of the bolt in.
Take that thread out, and throw that away with the 'fork' bit.
Get a small M5 (Magura bolt size) bolt, and cut across the head of the bolt, so the metal plate (other part of the TPA) can slot into it.
Once you've done that, just put it all back together. And you won't even tell it was broken!
Hopefully that'll make sense as you do it, otherwise just ask in here. (Y)
