How Can I Make My Bike Lighter Without Drilling Anything
gu trials
spec:
gu le 08 frame
echo disk forks
echo hedset
echo tough bars
echo external bb
gu cnc'd cranks
rear wheel: tryall rim..king hub
front wheel: tryall rim.. echo hub
rear brake magura
front brake bb7
dmr v8 pedels
grips- token lock ons
cheers if you can help
You could get:
Lighter cranks
Cut a wall out of your front and rear rims, making them both single walled, As well as using packing tape instead of anything else
Mag pedals
foam grips
What tires are you running? Should be able to save a lot of weight with those. And tubes too if you're using oversized ones.
Take a bearing outta your headset and put in oil instead of grease.
Take the half the pins out your pedals
run a smaller rotor
ride without a bashring
gripless
cut your bars like all the way
file down the material in your pads to almost nothing
take half the spokes outta our rim and lace them radial
grind your rims until the sidewall is super thin
cut half the threads off of your nipples
no rim tape
cut down the shrader or presta valve
remove all stem spacers and place the the star nut at the very top of the steer tube
cut the threads on all bolts down to halfway
grind tread off all tires until bald
shorten break levers to stubs
run as much separated cables as possible to reduce housing weight
run breakless
ride naked
take a crap before every ride
Dude common like what u want different components or what how can you reduce weight with all that echo stuff man.
We need a little more info homes!!
spec:
gu le 08 frame
echo disk forks
echo hedset
echo tough bars
echo external bb
gu cnc'd cranks
rear brake magura
front brake bb7
dmr v8 pedels
Dob Frame
Dob Forks
CK Headset
Monty Ti Bars
Monty Ti Stem
Try-All/MOE/Neon BB
Try-all/Neon Cranks
Dob rim/CK
Kamel Rim/Try-all 100 H
Rear Magura
BB7
Mag Pedals/Cages
Foam Grips
Should Will get sub 8.5 easily with that spec.
Edited by Mark King
Some possibilities:
gu le 08 frame Not much you can do with the frame, maybe stop running the bash plate and run a bash on the cranks instead.
echo disk forks
echo hedset These are fairly heavy, replace it with maybe a Meta or Tensile both of those are fairly light.
echo tough bars
echo external bb Quite heavy i think, best bet going for an echo internal or trialtech M15
gu cnc'd cranks Again quite heavy, could replace with Trialtech cranks if on a budget or Try-all, run an screw on cog and something like a trialtech bash.
rear wheel: tryall rim..king hub Get rid of whatever rim tape you are running and get some wide clear packing tape, much lighter.
rear brake magura
front brake bb7 BB7's are fairly heavy, Hope mono trials are lighter.
dmr v8 pedels replace with Welgo Mg1's
grips- token lock ons Get rid of lockons, get some trialtech foams they rule!
What tyres do you run? maybe cut off every other knobble around the sides, makes them lighter but also more grippy (Y)
Thats about all i can think of at the moment, i am not sure how much you would actualy save but it would be abit.
Adam
spec:
gu le 08 frame
echo disk forks
echo hedset
echo tough bars - Rage bars?
echo external bb - Internal BB
gu cnc'd cranks - Try-All cranks, trialtech half bash, trialtech sprocket
rear brake magura
front brake bb7
dmr v8 pedels - Wellgo MG-1s
grips- token lock ons - trialtech foam
Edit: Actually, read Bigman's post.
Edited by Quackers!!
