My Computer Wont Play Sound! :(
stunt man t
what Sonny said about finding the motherboard info will probably work.
Could try using this follow the drop down boxes to select the machine you have, I did a quick run and it's all there but I don't know enough about your machine to be 100% accurate.
Also you could try going Start > Run and typing "dxdiag" into the run box, then click sound. It should tell you what you have.
Edited by Dan Campbell
