What Is Beter Tar Or A Grid
mr.zoot
I use candle wax round my rims. I would say that it offers you almost as much grip in the dry as using tar and it has just as much grip in the wet as it does in the dry. Another bonus that it has over tar is that it doesnt make that horrible squeeking noise.
That's actually a really good idea, but HOW on earth did you come up with it? lol :P
My dad actually told me about it because he used to use it when he did cyclo-cross to improve his braking power. All you need is a candle and rub on a thin layer of wax onto your rims and your in business...
i really cant see this working at all.....
i used to use candle wax on walls etc when i used to skate
It does actually work. It works in the same way as tar does, by creating a "stickier/gripier" surface for the brake pads to grip onto when you break.
Edited by neotropolis
yes but skaters use wax to make something slippier so they can grind on it.
Guess the wax is used in the same way as waxing surfboards, cant see it being as good as a decent light grind :)
i've used surf wax on my rims before lol, it didnt work
and surf was is different to candle wax..
Edited by Grant-Hundley
Yea, i know of this, but the skateboard has a lower coeficient of friction than a brake pad, so where the wax helps the skateboard to slide, in the same way it helps to prevent the brake pads from sliding/slipping.
