Strong Rear Wheels
mattyboi
for mad strength if your running vees get a dx32, with disc or magura the Echo 07 (i think their called the TR rims now) are the best period.
Pro II hubs are really really nice if you want a freehub, for fixed get a surly or echo with a monty or white industries freewheel.
I would have to vote for an Echo rim in this situation. They may be heavy but they make up for it in the strength ;) As for a hub, if you are wanting to run a freehub then a Hope Pro II is the best value for money option but if you are willing to spend a little more on a hub they you can't go wrong with a Chris King ;) On the other hand though, if you are wanting to run a front freewheel then a monty, koxx, viz or trial tech hub will do the job perfectly. With a rear fixed hub you will want a good front freewheel, I would reckommend an eno if you can afford it but if not then a tensile will do a very good job ;)
Aden :) :)
why just use vee's on a dx32 :S
anyway, echo rims suck! they flatspot and bend. only good point is they dont dent till you've done about 15 grinds
dx32's though, hold grinds amazing, are stronger than echo's and they are lighter.
and a king would be best :) i've seen a lot of pro2's break... yet to see a chris king die
