Where Can I Get These Axle Bolts From?
weirdoku
Hi,
I was trying to take one of my almost dead bearing out of my hub (ZHI fixed rear), the other bearing came out easily but this one was harder so I had to hit the axle to try and pop the bearing out. But, I forgot the axle bolt was still on so it ended up like this. Its M10 size and it's hollow inside, allen key type.
I don't want to use a normal M10 bolt as the threads will dig into my dropouts.
Help please!
Edited by weirdoku
Hmm asked the place where you got the hub from?
I got the whole bike second hand, trials-uk sells the same hub but doesn't ahve that bolt listed.
Tarty do do the deng ones, I have a bought them from there before. Apart from that take it to a bolt factory and they will have loads.
Which deng ones? I can't find any other than the hope pro2 hub axle bolt and the titanium m10 bolt on thier site.
You can buy M10 bolts without the thread all the way up them. Take it to a local bolt place in an industrial estate, with the hub too, and tell them that you need it for that, but not threaded all the way. They're bound to have some!
M10 shank bolt (Y) , make sure you get one with the correct length of shank. I'd get two so that they both match.
phone tarty, I am sure they will be able to sort you out, they are the same as the adamant/czar/echo/etc... hub bolts
Looks the same as whats with the deng hubs, when i had my adamant freehub the bolt looked the same as that.
It is the same make basiclly all deng products.
No, I emailed tarty about the Hope pro 2 axle bolts (only axle bolts they have) and been told they won't fit because it has a different thread.
that is right, the pro 2 bolts are different but the deng ones are not.
my mate has just brought a new rear hub as his zhi hub nackred so im sure he will have his spare lying around for a couple of quid.
How can I get into contact with your friend? My msn is weirdoku@hotmail.com if he uses it. I'm on quite often.
Okay, does tarty sell these 'deng' bolts then? I'm assuming they don't have it as they don't have it on their site. I'll phone them tommorow.
Does anyone know where I can get partially threaded M10 bolts from? I had a look on screwfix and ebay as well as some other sites but can't see to find these M10x30 partially threaded bolts.
Technically its just a bolt. To be Pedantic, no bolt has thread all the way up, they all have a shank. A bolt with no shank(i.e threaded to the head) is called a set screw.
Just measure the shank,find a m10 bolt with the same size shank and buy it, you can always cut it down with a hacksaw (Screw a nut on it first, use the nut as a cutting guide, and to clean the very end threads up as you take it off.
