Grips Help :(
Matt Kerley
I had the same problem the other day, i tried numerous things, and then i tried aftershave :giggle:lol, i put a few squirts in each grip, slipped them on and left them, when i got my bike after school they were rock solid. So yeah try that, should work for you aswell
Cheers
Tom
well i originally used superhold hairspray and that did not work :S
cable ties?
I know this sounds really patronising, but did you leave the hairspray to evaporate for a few hours before riding the bike? It doesn't matter what you use to get the grip on - if you instantly ride without giving your liquid of choice time to set/evaporate then it's not going to have time to stick the grips to the bars.
I generally use water to slide my grips on - the inside of the grip is sticky enough to adhere to the bar without any extra adhseive, so I'm using the water for lubricant alone. Once it's dried off, the grips natural friction keep them on the bars.
If you're using hairspray, I'm assuming you're using it for both lubrication and for adhering it to the bar. Hairspray isn't generally noted for it's adhesive properties when it come to rubber and metal, so you might as well use something with a decent sticking ability. Spray paint generally works well. Clean the inside of your grips and the surface of your bars to make sure there isn't any residue from the hairspray, spray a liberal amount of paint into the grip and slide it onto the bar. Leave it to set for a few hours, and the grips should be firmly stuck to the bar.
If all else fails, you could try lock on grips. They have a plastic sheath inside them which is tightened at either end by an allen bolt, so you're bolting them to the bars rather than sticking them. They're available from pretty much every half decent bike shop nowadays. If you have a halfords local to you, you should be able to get some from there.
Edited by Rumplestiltskin
