D521 Rims
Rich Pearson
121 is nothing like a 521, It's slightly narrower, shallower and eyelts are much bigger inside. i have an unused one :)
121 has much beefier eyelets that go right inside through both walls.
And a d521 is 28.5mm wide, not 21 ;)
Leon
Edited by LEON
Not if you're trying to work out what width a tyre will be when you move to a rim of a different width - some XC frames back in the 90s couldn't take anything bigger than 1.9" tyres, even on rims that are pretty narrow by modern standards (I had the misfortune to own one of them :()... With Canti brakes the outside width of a rim is pretty irrelevant as they'll accommodate pretty much any rim width, and that was all that was available when the naming convention was devised.
Edited by psycholist
