Water Bleed Or Magura Oil Bleed?
*go for glue!
please search through the forum before posting one of these useless/pointless topics :rolleyes:
* = not reccomending it.
Edited by Nick pyke :)
*go for glue!
HARSH!!
I run water in my maguras and have had no problem with it. I have previously used oil and if you split your pipes or cross over there is oil everywhere, it isnt very nice and apparently peals the paint work off. If you split your pipes when running water, you dont get all the mess you do with oil. Also water reacts quicker on the pull of the leaver. But obviously water will do something to the pistons such as slow them down.
willlis x
:) Magura oil bleed feels really spongey on the lever its poo :)
i have used water since started trials it has a solid feel :)
If i was you i would use water.
tom x
Maggie oil doesn't make you brake feel rubbish, i used plastic backings for abit with and oil bleed and it was fine.
Iv'e now got CNC Coust on a water bleed and they are amazing!
I'd recommend using a water bleed, and to use 3 in 1 oil to keep the pistons from sticking.
Ginger Allen
