Grinded Or Smooth
smithy2050
Please bare with me as I am a bit of a newbie, what is this tar stuff you speak of?
Also would someone mind posting the pro's and con's of grinding/not grinding?
Basically if I decide to spend £100+ on a wheel the last thing i will be doing is paying someone to take a Dremel to it without good reason!
Edited by dirty-boi
You can get a pretty good set up without a grind, I run rock greens in CNC backings on a smooth rim and they work perfectly. The downside is that riding in the rain is an absolute no-no, unlike with a grind where you brake still works. What I would suggest is keeping the rim smooth and buying some smooth pads and see how you get on. Then if you find the brake is not performing to your satisfaction then change the pads and get a grind. For some, tar adds to the performance of the brake and is simply a lump of roofing tar rubbed on the rim, still has the disadvantage of not working in the rain and a lot of people believe it is more hassle than it is worth. While I have never done it, grinding a rim is not as drastic as it sounds, and your rim will still last a fair old while and take quite a few grinds.
lol you could supply the forum and have some left over
I agree, well at least you won't run out any time soon.
Thanks for the replies peeps, you've answered another of my many stupid questions!
I have a large sack, like that one, full of them.
I run a light grind, with some tough pads (ashima, new brand) and a bit of tar. Runs perfectly, and is sharp and grips well.
Also, for the record, My brake is water bled. Being water bled, the brake is more responsive, and feels much nicer than an oil bleed. Only downside is they need bleeding more.
Danny
I'm going to be the first person to say it's purely dependant on your kind of style of riding and your weight. If its purely TGS style with 99% static moves then a decent grind and some nice pads like the phatpads or coust pads will do you great.
If you fancy something a bit more all round then a lighter grind or smooth rim would be more beneficial as trying to learn manuals with a harsh grabbing brake is going to make learning a lot harder for you.
Likewise, the heavier you are the harsher your going to want your grind really as it'll take more to stop you. Brakes that are fine for a lot of my friends i wouldn't even think of trusting on just a curbstone because i weight a little more than most of them.
