Why Do 19' Rims Measure Across To 15.5'
Jordan GU
its 19" when un flatten the wheel, e.g. if you unwelded the weld, then unrolled it it should measure to 19", What are you doing now ?
Yeah, that would be the case if 19" rims had a 15cm radius. But they're a bit bigger than that.
19" relates to the size of the wheel with the tyre of a given profile, not the actual size of the rim.
Since 19" wheels use a different tyre profile, they have the same diameter as a 20" wheel.
