Do I Need A Spoke Key
rab shropshire
di i need a spoke key too true my wheel or can i use a flat head screwdriver on the nuts that are inside the rim
Yes you need one, the screw heads wont supply the torque required to tighten the spokes :)
I would recommend loop type park spoke keys, expensive but never had one slip and very comfy to use.
Spoke key.. sometimes the spokes stick out the top of the nipple a bit and you can't et a screwdriver in there anyway. The £3.99 or whatever is also worth it for the time you save taking the wheel out, tyre and rim tape off and whaking it all together.
Truing wheels is piss easy, and if you don't try it you'll never learn how. It's pretty hard to properly f**k a wheel up, so even if - somehow - you can't get it right, it's still going to be the £6 you had to pay the shop in the first place. Just read the Wiki and give it a go. Just do it bit-by-bit, and don't rush it...
I'm stealing this idea from someone else, but get a couple of cable ties, one round each fork leg, then trim them so they can be rotated to rub against the rim like a brake pad would. The only disadvantage of not using a proper stand is that the rim can end up off centre from the hub, but I don't know how much that matters, and it's pretty unlikely if you are just correcting a mostly-ok wheel.
