Zhi Rim/pad Combination
Matt Vandart
My ZHI rims appear to be made of cheese and will not hold a grind with ONZA yellow citrus pads.
I have plasmatic spannish flies on there now with a dead grind but they are a bit lacking in hold capability.
Any suggestions for pads that will not flatten my grind in about 2 days?
Matt
Even if your grind is flat, the tnn engineering yellow pads (CRM compound) will work perfectly! ...untill it starts to rain
My heatsink reds work amazingly on a worn down grind, and don't change when it rains - if you can find a pair for sale anywhere definatly get them. Otherwise I'll recomend Koxx Browns / Phat Pads as both of these pads have worked quite well for me on a similar grind, both had great hold, but the bite and noise wasn't really there. 'Hold' is all you ever want from a brake though right ;)
Thanks dudes, are you all suggesting these pads cos they work with the ZHI rims? Because they really are soft.
I ride alot, from 1-5hrs a day.
The grind went flat in about one and a half weeks on my ZHI rims, the same grind and pads on an ONZA Ronnie/reggie lasted about a month and still were not flat when I put them on my broinlaws bike.
Hmmm..........
Matt
