Chain Tensionisers
bikeperson45
My Onza derailleur is dead now, and was wondering whether I should get a cheap short arm mech again or make the leap to a tensioniser.
I have a Hope Pro 2 trials hub, 18 tooth chainring and a 1/8"chain. I've looked on Tartybikes and saaw the Tensile and the Atomz.
Would either work on my bike? What scares me is they both look derailleur-ish. Would they brake as easily as a derailleur after a big knock?
And would something like this work?
http://cgi.ebay.co.uk/Gusset-Bachelor-SING...e_cycling_bikep
arts_SR?hash=item3a528a51da&_trksid=p3286.c0.m14
Thanks a lot
Edited by bikeperson45
Get a sprung tensioner if possible ;) Fixed tensioners are usually pretty crap at keeping tension..
A 74kingz or a rohloff is the best options. But I have heard good things about the tensile ones too :) The long arm tensile one should fit your setup ;)
Thanks for help
The 74kingz have been discontinued haven't they?
Anyone use a Tensile? I'm curious about their strength
Thanks
I use both a 74kingz and tensile... not at the same time obviously :) ... i prefer the 74kingz as it is will tucked out of the way and won't shag the hanger or frame if you land on it heavily. Only issue, as you said, is that they have been knocked on the head and i am using hacksaw blades as the spring.
The tensile is very good and helps wrap the chain around the spocket better... it has more adjustability than the rohloff. It is the same as the koxx and various others, come out of the same far east factory!
would a tensile long arm tensioner do for my dirt rig?? its an old skool saracen x-tort i bought off here the other day...it has a tensioner and mrp style chain guide on the bb,but the derailleur on it at the moment is shagged..so need a replacement.....and because im thinking of just going single speed with a hard gear for freeride and jump i was considering the tensile tensioner with a long cage?? help please
i use this tensioner http://tartybikes.co.uk/product.php?produc...category_id=113
Its very strong and i have given it a hard time but it still holds out and neither has my hanger broke XD.
Go for it!
How do you find it? I'm tempted by it because it looks simple and less easy to destroy
Can you only get the 74 kingz tensionisers secondhand now?
Thanks for help
These are good for the money. Bad-oiiiiing
Before I go for that, can someone tell me what this means?
"• Maximum front difference - 16 tooth"
Does it mean the difference in number of teeth between front and back?
I run 22t front and 18t back, will it work?
Thanks again
Edit: Found out max teeth on back is 20
