Tnn Pads O-Rings.
Revelation
My TNN pads o-rings got f**ked after I refilled the pads for the first time. Now the pads dont fit to the HS33 anymore.
The rings are now f**king loose.
f**k O-rings, I'll go back to Rockman blue pads
Thats all!
Man up and get a grip, you woman!
i did this my o ring went so i used rockman blue they then decied to stick and a broke my arm so rockman blues can suck my shit
tnns have new O ring courteous of ALI c of tarty bikes and is mint! fix the tnns and get em back on
You can pretty much garuntee it wasn't the fault of those pads, it was probably a sticky slave or if you were using tar.
I've been using powerpad backings on and off for 3 years, and I've never had a problem with them, or heard of anyone else having a problem.
A tiny spot of lube on the o ring helps it glide on to your pistons. I had a similar problem with them turning inside out and not holding the pad on. Turned out I just needed a bit of lube on the o ring and the popped on no problem. Mr Tart saved the day for the 24905237850502nd time.
Ding ding ding! That's all you need to do. The reason the O-rings mess up on most people's setups is them forcing them on with no lube at all. It rapes them if you do that, so you just need to lube it up first to make them last longer (Y)
