Diamondback Tekiya
alder93
hi, iv just got a couple questions...
first. its got hs33 brakes and the rear is touching the rim. iv looked at it(but im useless with hydraulics) and i cant see how the pad can possible move further away from the rim. i think its because the diamondback rims are a different sort of double walled rims. they seem different to the other trials rims iv seen before.. does anyone else run this setup and its ok?
iv read some reviews on the tekiya and a few say they snapped. is that off extreme drop-offs? or is it worse than im expecting?
thanks!!
thanks!!
Sounds like your brake isn't set up properly. follow this video here: Clicky Click!
I can't see what else it could be except a badly set up brake
thanks, i remember trying to move them like that, but they were already on their limit. :S
but whilst checking i noticed id missed a massive buckle in the wheel! now i feel like a bit of a tit for not seeing it in the first place! lol
cheers!
cheers!
Yeah dude, that probably don't help :rolleyes:
Or if your wheel isn't centred between your chainstays, it won't be easy to set up
Get your wheel sorted and try again :) if you still can't move them far enough out, you might need to get offset mounts, if you're using 4 bolt magura mounts?
yeh, 4 bolt. il let you know how it goes..
cheers
I had one of these awful bikes. The only way to stop the rear pads from rubbing on the rim is to grind them down but its a big waste of material. Hope that helped.
Also they flex really badly.
thats what i was hoping not to hear! haha
and the entire frame flexes?
on the bright side, im already saving up for when i break the frame! haha
thanks
I had the diamondback all in all i thought it was a good first bike but i have just snapped it after five months ridding. The only reason i found that i could not get clearance for my magura was that the drop outs for the wheel are offset this means the wheel sits closer to one side. What i did was got a spoke key and realigned the wheel so it was central. This gave me clearance.
And also with the flex in the frame i brought a two bolt boster from neon cost 16pounds stopped all the flex and made the brake so much better.
Hope all this helps Aidan (Y)
well il do what i can :D
baring in mind i cant even bounce on the back wheel yet i think il be ok for a few months yet
i wont bother spending any money on this, i think il just wait for it to snap and go from there.
if im lucky it might snap in the next few months and i can try weld it before i finish school! haha
thanks people!!
well i got bored waiting for the bike shop to have a time slot so i had a go myself...and i dont know how, but i managed!! lol
theres still abit of a buckle, but id say its less than 1.5mm and its spinning in the brakes fine. so im proud of myself!!!
