Limey 320
that NBR dude
The resident bike whore returns...
Picked this up at the weekend, first impressions are really good, aside from a few design flaws. Few tweaks still required, but all good so far.
Spec: (slightly different to pic)
Limey 320 frame
Zhi SL fork
Hope Mono Trial front & rear
Trialtech highrise bars with Trialtech race stem
Trialtech cranks with Trialtech Ti halfring bash and Atomz pedals
Trialtech Rims front & rear
Rockman Bub disc front hub, Profile disc rear hub
Creepy Crawler tyres
Yea I gave up with my rear disc as it rubbed ridiculous amounts, no matter how far I shimmed the calliper.
I also found that the rotor hit against the frame, so there was one a few positions that you can place the wheel.
Also likely to crack around the seat tube, where the weird tangly bits of metal are, I think they are designed to be there to crack as a stress point, as apposed to the frame crack in a more serious location.
Edited by Captain Scarlet
Been tinkering around with the rear profile, and managed to get the rotor far enough away from the frame, but had to shim the caliper a bit.
Should be ok, chain lines a bit shabby though. Need to sort out the cranks / bash / sprocket combo, add in some more spacers to make the chain line better.
And Dave, yes I know. I'm really not digging the jewish racing gold. WIll be sprayed soon enough.
