Rim Brake And Pads?
charliet
What rim brake should i get?
32 members have voted
  1. 1. What rim brake should i get?
    • Echo SL Rim Brake
      2
    • magura hs33 05+
      17
    • magura hs33 2011
      9
    • echo tr rim brake
      4
  2. 2. what brake pads to have on i grind?
    • TNN Engineering Belaey
      3
    • TNN Engineering LGM
      12
    • Heatsink CNC Yellows
      10
    • RockMan CNC Blues
      0
    • Phat pads
      7
Echo Sl brake is a winner mate. Great feel, good looking and the slaves hold the pads much more securely. Very good brakes. Every thing from the positioning of the hose on the body, the way the levers held in place is brilliant.
Pads wise, Heatsink Yellows for sure. Brilliant compound gives amazing bite, shed loads of hold wirh a good loud honk and are very reliable. Will work brilliantly on a smooth rim with a tiny bit of tar, or grind your rim for the same amazing performance but with the added bonus of being able to ride in the wet!
Although TNN LGMs are also a good choice. You have to run a decent grind, very harsh to get the best out of them in my experience. Bite, hold and noise are all fantastic. Brilliant pads. Il be running mine again when I get another grind, then use my yellows when the grind dulls.
Hope I helped :)
Hope I helped :)
brilliant!
Edited by Manus-Rider
Ive found that If you use the 2010 SL complete brake lever unit with maggie slaves you get another bonus.
Echo slaves have less inwards adjustment than magura slaves.
So may not work if you are running widely spaced frame and narrower rims.
Forgot to add that Magura Hs33s 2005 are brilliant too. Lots of aftermarket parts you can fit, and feel great with an Echo/ any Deng lever/ Magura 4- Finger lever. Bleed it with Phat Phluid or water with antifreeze mix for the quickest and snappiest feeling brake, but stick to oil in the Echos if your running the original slaves.
If its any help my brake is amazing at the minute, spec as follows.
Magura 05 Hs33 / Echo Lever / Pure Water bleed / Standard hosing / Bath bled
Echo SL 2 bolt booster
v!z Clamps (with plastic cylinder washers)
Heatsink CNC yellows
Trialtech Sport 19" Rim
Sharp light grind.
My set up with the TNN Lgms was;
Magura 05 Hs33 / Oil Bled / 4 - Finger lever / Standard hosing
No Booster
Atomz Elitis TR clamps (Soon moved to the v!z clamps)
TNN Lgm pads
Trialtech Sport 19"
Mediumish grind.
^ Brake worked brilliantly, and would be even better so with a deep, sharp grind. These pads have a brilliant wear life so dont be afraid to run them on the harshest of grinds. Would be improved further with a faster brake (water bleed), the hold would be increased with a booster, and the overall performance with a deep or harsh grind.
Again I hope this helps. Have had too much experience with setting up brakes for myself ( I love to test what pads are out there ) and other people. :D
Theres no coust option to vote for, so i cant vote.
:P
Im currently running a 05 maggie with coust pads with cnc backings, four finger lever and water bleed in the maggie with TR mounts. must say, its the best brake ive ever had... Lgms are okay.. but very tempermental i found, currently running beleay pads on the front with the same maggie setup as rear (4 Finger, water bleed, tr mounts) and theyre the same as i lgms i found, just not as tempermental.
If you can afford it get CNC Cousts. The best pads I've used and I've used TNN LGMs, Heatsink yellows,reds, and old zoo! Pads.
+1 (Y) for coust in CNC backings.
:P
Iam looking to change pads and were can you buy coust pads from?
