Whats Wrong With My Tpa
tdubz
out riding today and wanted to make a slight adjustment to my lever pull on my rear brake
usually quarter turn on it and i get some kind of difference
turned it today and nothing happened
im going to take a picture of the lever maybe tomorrow because i think one part of the blad and ?piston? have become misaligned causing the tpa pin not to push properly when turned
but before i go taking my lever apart i wanted to ask what could be wrong because as it stands the brake works but not as well as it did, the brake is rideable so with the weather we are having dont wanna take the bike off the road so to speak unless its a quick easy fix
picture added to help diagnose the problem maybe.....
thanks
Edited by tdubz
Sounds like you've sheared the threaded section of the TPA - it's no big deal, you just need an M5 bolt to put in there instead. If you take the lever blade off (easy to do) you can push the TPA assembly out and it'll all become clear. There's a thread about it somewhere on here too...
if the tpa has been maxed out would it just be a case of taking the lever blad off and winding it back in building it back together?
removing the lever blade will that effect all the "balance of fluid within the system" resulting in me having to rebleed?
thanks
thanks
You shouldn't need to take the blade off, just back the TPA back off all the way. You shouldn't have to bleed the brake but you will have to set it up properly at the wheel. That's assuming it is maxed out of course.
