Ozonys Curve 2 - 7,18 Kg
G_!
Is that rear rim a modified Pro Light rim or a new Bonz rim (Racing group at a guess)?
are your cranks on tight enough? just there's a long of spline left that's all.. BAR that bike looks amazin!!
sorry, Carlos Vazquez is not in this forum and i can't answer any question
I guess you could potentially break the sub 7kg barrier if you go all out no expenses spared with ti parts and without butchering the bike with drilling holes and cutting out sections of the frame.
Edited by Rusevelt
easily can get that sub 7KG just cut the stem stackers out and wear the tyres down abit. soon would be below 7KG
What?!
how much do you think stackers and tread weighs?!
The heavy bit of the tyre is the casing and bead.
That is a nuts weight i'd be very scared to ride it.
  • 3 weeks later...
  • 2 months later...
