Big Sidehop
pete trials
try to less jumping on rear wheel, and pump your rear wheel to normal pressure (you got it so hard) :-)
He's right. Your way isn't wrong but, if you tried to slow your hops down on the back wheel, you will find it much easier to get into the right place/position to take off.
Edited by pengsmelly
Nice. That height is about my limit for sidehops! Anywhere over bar height and I struggle. :(
I'm the same so I plan on raising my bars in order to trick my mind!
6 pallets is pretty good though I agree with the hops and the tyre pressure, I was the same and it helped no end!
