Tensile Offset Mounts
murph82
- Patented offset mounting method allows the cylinders to be positioned slightly further out than standard mounts (but not further in - see photos), ideal if your rim is a little too wide for the frame.
http://www.tartybikes.co.uk/images/custom/large_tensilein.jpg
http://www.tartybikes.co.uk/images/custom/large_tensileout.jpg
They do work when running them to position them further in. Mate next door had been riding his Echo Lite 09 with an Onza Pro 38mm rear rim for a year using them set inwards and his brake worked fine.
I think theyre shit though.
They are not bad... I use to run them on my old pure 06.5 with running a 47mm try-all rim and found it hard to get a good brake set up until i discovered the tensiles which were perfect.
Its for those with either skinny or fat rims who struggle to get a good brake set up.
Andy
