Inpulse Start - A New Range From Inpulse
54Sport
Inpulse have added a new range to their 2013 Line up and we thought you would like a look :)
The START range will feature 3 new models. A 20" kids bike, a 20" and a 26" ( currently being ridden by Aurelien Fontenoy world No.2)
The start will slot in just below the 'R' range price wise, however It is no less well equiped and they are looking like great bikes.
If you have any questions or would like any more info email Info@54sport.co.uk
INPULSE START 26"
1075mm WB
378mm CS
71 HA
50mm BB
INPULSE START 20"
1000mm WB
350mm CS
71 HA
70mm BB
INPULSE START KIDS 20"
920mm WB
350mm CS
71 HA
70mm BB
Edited by 54Sport
  • Like 1
Wow, really really nice bikes. Prices?
I really agree, nice and clean (It's nice to see a frame with no headtube cutout too. yay impulse!) I was just about to ask about price too.
does it have a built in booster? its hard to see the machining around the back brake
Bottom piccy suggests i doesn't, but surely that's no problem, bolt on boosters work better anyway IMO.
Also is that an internal, as in cup in frame, bearing in cup headset or a intergrated, as in bearing on frame, no cups.
Clarify please someone. thank you.
Great to see so much Interest In these bikes. I am getting answers from Inpulse to all of your questions so bare with me!The 26" frame comes in at 1.5kg and will be availabe in either twin HS33 or Hope/HS33. UK prices are not 100% fixed at the moment but.... The full build will be around Echo SL price range (depending on brake option) and the 20", again depending on the brake option (Twin Hope or Hope/Hs33) will slot in around the the rockman manus.Direct from Cedric@Inpulse talking about the start 26" -"Yes the Start 26 is quite short (compared to the current norm) but comes with 150mm stem, which Aurelien is riding with now with. Shorter bike is better for bunny up and more easy on the front. Moreover, it is a middle range bikes, so for quite tall rider and quite technical level. The bike is more easy to ride than the R26.The parts are suitable with R bikes."
A few more pics
4037901_orig.jpg4726534_orig.jpg3842535_orig.jpg5003909_orig.jpg9360608_orig.jpg1767365_orig.jpg
EDIT: No built in brake booster with these. They also use a semi integrated headset, the same which is used on the R series. Might be able to see it better in this pic
Edited by 54Sport
They also use a semi integrated headset, the same which is used on the R series. Might be able to see it better in this pic.
so in relation to my earlier post, bearings in HS cups or direct on frame.
EDIT: Frame only to come?? Price and mounts on said frame (stock)
EDIT2: OT: What is the feedback, customer or team, like at 54sport concerning the impulse freewheel.
Good, bad, ugly? It looks a lot like the try-all/trialtech freewheel, correct me if i'm mispoken.
Edited by CC12345678910
1- Bearings In headset cups
2 - There will be a frame only option. Price TBC. Hs33 mounts on rear, no news on them doing rear disc anytime soon. Unsure If they will do forks with both mounts at some point
3 - Good. Reviews so far have been positive. Not had anyone say anything bad against them. As long as you take care of them like all freewheels, clean them out now and again etc they should run spot on :)
Not sure what the closest comparison to a Inpulse 108 would be, sorry
