Massive Problems Since Going To Ffw
tdubz
Moved from pro2 to freewheel
1st issue
when i tighten cranks onto bottom bracket they sit flush to the frame bb so wont spin, tried using a small shim but it killed my bottom bracket
2nd issue
cant get the chain line right on my gusset tank chain since going to ffw, its rubbing the chainstay
3rd issue
cant get the chain tension using snail cams even at the largest section of the cam
really regretting doing ffw at the moment seems to have made my bike terrible
cranks i have are these
bb i had (possibly get another if will work) is this
freewheel is this
frame is a because 24 pure trials
gusset tank chain
monty cams
14t sprocket
Wider bb. Trialtech Sport lites are good, or even the cheaper Race bb.
Narrower chain. Highly recommend the KMC Z610Hx 1/8"
Cams with a wider range of adjustment, Echo TR
Will sort your issues.
I thought the TR cams have a very small amount of adjustment?
