Echo Chain Tensioner
ForrestDump
Evening everyone,
So... I've recently bought an Echo Lite 2011 frame (Thats the 20" one for those who don't know) to replace my old Zoo! Lynx frame. I was surprised to see the new integrated tensioners in place of using the snail cams that I've grown so fond of using. I've been setting up the rear disk and just taking the bike out for the odd hop around recently to make sure all is in working order and have come to notice that the chain seems to slack off more than it used to when using cams.
Maybe its just because I haven't used these tensioners before and haven't got them set up properly. Has anyone else had this problem, and what was the solution? I do tighten the chain on the 'loose spot' so it is nice a tight if thats my first problem...
Anyone know why snail cams have been scrapped?
Thanks,
James
Evening everyone,
Thanks,
James
That might be the problem.
is it just your chain stretching?
Dont think so, when I say I'm just going out for a little bounce around I mean it, it really is just a ride round the block.
Never had an issue with integrated tensioner, are you screwing them all the way in to tighten the chain? Both sides?
Sure am, I'm not that silly enough to tighten the chain without them. I guessed they were there for a reason.
The thing with this is that if I don't tighten on the loose spots then when the wheel goes around it gets slack anyway and the gap between the frame and chain is tiny. It is a fairly new freewheel so maybe it still needs wearing in. I've always tightened on the loose spots before and had no problem.
If you do it that way it will be most likely too tight on the tight spot,this could cause chain to stretch more and also damage freewheel etc. I would recommend you do it this way:1,Set the right tension on tight spot(in this position you can make it really tight)2,tighten up the hub bolts 3,tighten up the chain tensioning bolts some more so they won´t come loose.
That still wont stop having the really slack spot though...?
Just put some thread lock on the integrated tensioner bolts. Stops them from un-doing..
Did you use the red or the blue stuff for this? I just assumed that there would be thread lock on it, I guess not.
Thanks for all the replies.
Blue if you need to, but usually nipping the grub screw against the axle AFTER you have tightened the axle bolt does the trick though.
The standard grub screw are cup point which do dig into the axle a bit, this is another reason for the chain seemingly becoming slack. Keep riding, keep adjusting, and it will settle down.
Thanks Adam. When tightening the chain do you do it on the tighter or slacker part? Just thought I'd ask to clear things up haha
As has Adam said, use the blue stuff.
I try to tension my chain on the 'in-between part', this means that the chain is slightly too tight at the tight point but the chain isn't overly loose at the loose point. It works for me (Y)
I go for the slacker part personally - the amount of tension you can create with the tensioner is nowhere near that when you stomp on the pedals.
Thats what I've done after watching your video... regarding the tight spot, obviously this becomes very tight. Will the freewheel naturally adjust to this or would it become damaged?
The amount of tension you can create with the tensioner is nowhere near that when you stomp on the pedals - therefore it doesn't matter IMO, assuming your cranks aren't a complete mess in terms of change in tension (cue dave33 disagreeing with me).
  • Like 2
