Major plumbing Issues - Trying to fix water heater.
JT!
I would've thought you'd be able to tell if the elements are heating by feeling the exposed part when powered up. As Mr Seamons says if they have power are you sure it's not something silly like your thermostat is set too cold, the timer isn't operating and that the water is actually filling the tank beyond the elements?
What is the voltage over there? I presume 110? If so, it all seems ok voltage wise. Is it 120 on both sides of the element?
When I measure across the element, it reads 0 volts. But if I measure any side of the element against earth, it reads 120v, even though both elements are 240v.
Tank is defiantly full as the hot water only comes out when it is full. Cold water comes in at the bottom and hot leaves at the top. There is no timer, just two thermostats, they are set quite high for now. There isn't really an exposed part other than the bolt at the end.
I can't remember what I have said on here and haven't as I have a couple of topics open on other forums. So I'll go over everything again.
The very first thing I did when I had no hot water was replace a fuse that went out, stupidly I replaced the one that had gone (there's two) and never thought to check it again assuming the problem was something else, like the elements.
It seems that the elements I took out were actually good all along and the problem is the water heater is just blowing out the fuse. I did get it to run for a few seconds ( I could hear it hum) then the fuse went again.
The hearer is 240V and can take up to 4500W elements, of which I have two in there now.
Apparently measuring over the element should give me 240V, however I get nothing, because the fuse has gone. I get 120v at any point relative to ground because 1 fuse has gone and not the other, one fuse deals with 120V the other with the other 120V (that may not make sense to someone who knows what they're talking about with regards to electronics but... yeah). Apparently measuring against ground is pointless as ground it not part of the functioning circuit.
Also apparently with my water heater only 1 element will run at any given time, the top one heats up first, then when the water at the top is hot enough, it'll switch to the bottom one.
Seeing as though the thing actually ran for a short period of time, I've figured that it can't be a short as the fuse would blow right the second I turned it on.
So today I'm going to replace both thermostats which seems easy enough and if that doesn't work I'll have to call an electrician as there's nothing else really that I can do. A water heater isn't anything more than 2 elements, two thermostats and a big container of water.
I've also read that a 240v element will run on a 120v system, but it will be 25% of the wattage.
