trial tech sport forks fitting on echo hub/wheel
AWT
- Dropout size 9.5mm to fit all standard 9mm axles (Hope, Try-All, Shimano, Chris King, V!Z, Onza, etc.). Echo hubs use a 10mm axle and will need modification.
- Weight: 896g (Disc), 900g (4-Bolt).
from tarty,
from tarty,
also from tarty:
Modify the hub axle rather than the fork - easier and cheaper to replace if it goes wrong!
