Pinch Flats And Rimming
Mr Motivator
Yesterday I was playing with tyre pressures, I usualy have about 23.5psi in my tyres back and front and find this a great mix between not rimming/grip/bounce.
Then I let out loads of air till I got to about 5-10psi. It was great for some trialsy hoppy hoppy and offered awesome grip, only problem was that it would rim like a hairy old man on ledges.
I thought to my self, "if only my tyre was this bouncy all the time and then as soon as I landed a gap it wouldnt rim out" :angry:
Then.. Idea! I remembered that I had a load of polyurathane pipe insulation foam [picture] left over from something or annother that I was doing a long time ago.
So, cut it down the middle, got my wheel, took out the tube, cut the foam just short and popped it inside the tyre. Then put the tube back in and the tyre back on the rim.
Pump her up to 10psi and away you go!
It bounces and grips really well but you cant rim it out, its great!
Dont worry weight weenies, it weighs 'nothing'.
So get down to b&q and get yourself some, its only about 70p a meter I think or possibly less.
Even if you dont like running really soft tyres you could still use it if you dont have good tyres (maxxis, mich (N) )
Anyway, thought youd like to know.
Sam.
lol (N)
Hehe just tested it with my old hot s (N)
My bed has a square steel section frame with sharp sides. Just put some left over foam in an old 521 and hot with a tube and slammed it full pelt into it.. no pinch, then did it where there was no foam again propperly full pelt, bending the rim and gave it a pinch.
Im gonna bring my hot s back from the dead! :angry:
Im gonna bring my hot s back from the dead! (N)
But they grip like oil. :angry:
Not a bad idea, i've got some blue stuff like that under my bed. May give it a try (not that i need to (N)), untill i get my new rim (Cough* Ali C!) and a new tyre and run tubeless again.
Mike.
From what other people have said, it doesnt sound like it would work, but if it does then it isnt a bad idea.
I think this is what tra must have done when he had his zoo boa then when he moved to echo, as his tyres looked like they were pumped to 5psi yet he still went huge without seeming to have any puncture problems :angry:
I used to like my hot s mike :P
Been for a propper ride on it today. Seems ok and not too soft, i pumpd her up to 15 psi now which is a bit better than 4 i guess :P
Seems fine on ledges and rails :)
Also;
The tyre doesnt roll off the rim as easy (Y)
You can stick pins in it :S
No pinch ;)
No rim :-
Yeah, just incase you dont understand or are interested;
Just looking at that pic, I can't understand how it prevents pinch punctures?
The pinch happens when the tube is squished between the tyre and rim... yet that pipe lagging only protects the top of the tyre...
I'm lost ;)
Think harder (Y)
The tube pinches when it is compressed between a sharp edge or rock and the rim. Maxxis tyres dont pich because they have thick softish sidewalls that cusion the tube, therefore the foam will help :S
2mins later..
Nah its fine, gone a little flatter not much though.
Maybe Im using something harder?
Surely you can see you've just made Toms point... you only put the lagging in on monday and it has already started compressing!
Will probably last about a week at a time.. at most.
Or you could just get a 2.5 maxxis minion dual ply, that is, to my knowledge, impossible to pinch! Grips like a homeless chav and harldly rims either with 25psi.
And you still get bounch! Probably weighs the same too.
(Y) :S ;)
Hearing that gets me moist every time
"60a Maxpro Compound". Oh, there we go, dry as a bone. (Y)"
And I can't believe hardly noone puts a load of talcum powder/ground chalk in their tyres, it just won't pinch like that! (With a maxxis :S)
Mike.
