Wide Rim
Whiteboy
ok well i want something a bit wider than my alex dx32 as setting up the brakes at the mo is proven quite hard as the brakes are all the way in and still got loads of tpa. so a wider rim should help. but i dont really want a koxx or anything like that as i used tio have mone and never had a working brake and dented it all the time. so i heard that sunn make some wide disk rims that you can just grind to make them rim brake compatiable. this true? what rim is it? and any other rims that are strong and hold grinds weell? eound the 40mm + ark?
thanks
Basically you've either gotta:
1. Use larger brake blocks or do a pad bodge and keep a decent rim
or...
2. Put up with a denting rim and your brake not working that great.
The only rims available really are 38mm wide or 47mm wide (apart from the Koxx XL but i don't think that's out yet :P )
Obviously the 47mm wide rims are the Koxx type rims that dent.
So yeh...
I would go for the viz rim, as it has eyelets and is very wide, the koxx drilled and onza hog rims dont have eyelets and are very cheesy indeed! Also the viz rim comes in loads of colours. Sunn double wide rims are bombproof but heavy, do like biketrialler said and drill it if you get one. (Y)
Im in the same situation at the moment too, didnt really want a cheese rear rim (although I settled for one on the front as no-one else offered the same sorta front rim width), but I definately want something wider than my 38mm dx32/onza rear rim.
Whats this about a Koxx XL rim??
i use a viz rims and so far they have been pretty nice. your always gonna dent a rim. just learn to ride better/land smoother.
this is a prime example or trials for you. its harsh on your bike. fact.
thechink
well, thanks for letting us know, :huh:
will. well thanks you pointless post aswell.
so is this post i just typed.
stop being gay and just stop being gay..........you gay gay!!!!
hahahahahahahaahahahaahahahah. im kidding.
no seriously mr. andrew chai has only put one little dent in his viz rim and you all know what the little lady boy chai is like.
thechink
when i saw you posted in this mr chink i knew exactly what you would be saying (Y)
i used viz rims, all i can say is never again. haha. if you like your rims lasting 1 week then they are the ones for you, but otherwise noooooooooooo.
chai is a smooth bastardooooo, i bloody well hope he hasnt got any dings...
Edited by James_Porter
when i saw you posted in this mr chink i knew exactly what you would be saying :-
But then again James, Your not partically smooth :) :P :"> .... and Viz rims isnt really produced for the type of riding you do.. Its like getting a racing bike and go DH on it (Y)
Fool :S
But then again James, Your not partically smooth :)  B)  :"> ....and Viz rims isnt really produced for the type of riding you do.. Its like getting a racing bike and go DH on it (Y)
Fool :P
no dan. it really isnt, i wasnt actually that harsh on the rim at all, it just didnt like holding out.
WTF!!!!!?!?!??!?!??!?!?!??!?!?!?!?!?!?!?! whats my sort of riding????? :S i ride trials like every other rider, so your saying that viz rims arent built for trials???
im confused :-
dan, im not trying to have an argument, your post just makes no sence...
well to be fair james not many people do 13ft drop offs and just pray their bike holds up too it, same for silly drops gaps and other 20ft to 1ft rails.
i dont wanna sound harsh, but i will just like to say that gaps like that isnt just abt having alot of guts.
if TRA had a viz rim i am sure it would last him long enough..
its the same as why Chris walker/Ben savage can use monty and try all respectivly and others just find that their made of cheese.
Edited by TheChai
