Buggin Me,
fairy elephants
isnt it just because the numbers 10-19 = the same number when you work it out which is 9
then the numbers 20-29=18 so that picture will be the same as number 9 etc etc etc.....
Near enough, nothing special. If it didn't pick your celeb you suck at maths.
I know a really good number puzzle, but it only works on people called Lee. Good though.
It works every time though with different numbers?
Just worked it out. the numbers you pick must always add up to a few certain numbers and the same pick will be on for all those numbers.
Edited by Anal_Teflon
so does anyone actually know how it works
yes...did you not read the thread? (Y)
the pictures 9,18,27,36,45,54,63,72 and 81 are the same.
if you do the numbers 10-19 they will = the number 9 on the celeb sheet bit
30-39=27
40-49=36
50-59=45
60-69=54
70-79=63
80-89=72
90-99=81
not too puzzling :D
Yes, it works out that every number u get will be a multiple of 9, and each multiple of 9 has the same pic...
Err nope...
It gave me three different celebrities in a row.
All of which were the right ones!
The same celebrity isn't on the multiples of 9, how does it know which multiple of 9 you ended up with?
Edit: I see it just uses the element of lcuk to do it... getting it to work for you three times in a row seems a fluke..
Obviously the answers are always multiples of 9 but weather it picks the right one is chance.
But it doesnt say which multiple of 9 it chooses, all of the multiple of 9 pictures are the same....so doesnt matter what number you do, you can just play the game look at number 9,18,27 etc on the celeb sheet and know which one it will pick....and the pictures change, each time you play
Edited by Bondy
I see you mean each time it reloads the pictures are the same for every multiple.
Hence why I didn't change my number the picture was wrong if i didn't look at the new picture.
