I Need Better Brakes
trials man josh
Bearing in mind after the grind it'll feel shit 'til it's bedded in.
Are your pads set up well? Square to the rim, decent distance away?
What is the brake bled with?
Are you actually landing stuff well, or are you riding shit and expecting the brake to hold?
i arnt riding with a booster do you reccomend it ?  ill re grind my rims and see what happens thanx for the help  :)
Jesus, Get your English sorted, boy!
Booster wise, If you're running 4 bolts then an RB or Echo Control/Team booster will do you well.
For 2 bolts, a SHimano XTR if you can get hold of one, if not just use the standard Magura one, or get a Salsa if using V's.
And yes, i reccomend a booster :)
well i run heat sink reds on a dead grind with tar and i think it works well good bled with water and have a onza carbon booster , but when you set up your brake fit a coin between the pad and rim this way the pad is straight and the pad does not rub but very close to rim, but when you do this to get th coin out undo the wheel so the coin can be removed
hope this helps
ric
