Disk Brakes
Trials mama
hell yes it is! i had a bb7 with nokon cable and an ultimate lever and it has nothing on the juciy-however the bb7 was an incredible brake and i would go back if i had to
basically the juicy wont overheat like the bb7 which i found to be a huge advantage, as well as that really nice lever-its well designed :)
bb7 if you on a budget, juicy if you want the best (i prefer them to mono trials, etc)
ok, I have a 180 magura marta caliper (160 virsions are easier to get at cheaper prices though) and a shimano xt lever.
I got my caliper from the shop I work at trade price for £35........there are often 160mm martas on ebay for about £40 onwards for a full disk.
I then got a shimano xt lever off ebay for £9
I am using standard maggie hosing and a mix of maggie and shimano fittings, they woulod cost about £10 at most.
You can pick up rotors on ebay for about £20
so that totals at £74 for a mint brake!! It just takes a little patience to wait for the parts to come up.
oh, and to whoever said magura disks are shit..... I presume you used the older virsions? they did have a habbit of leaking and pumping up. The newer maggies are MUCH better, very powerful.
Another key point to maggies that is often over looked is that the hose goes directly in the top of the caliper, making it very hard to hit and damage.....unlike hopes and avids which have a 90degree connection on the side of the caliper. I hit my hope on on my 2nd ride, and it undid the bolt, causing fluid to go all over my disk and pads!!
from my experience matt, id go witht eh juicy 5 for sure!
the juicy seven ive felt was just out of this world.... and if the juicy 5 is the same with a little less adjustment.... its GOT to be insanely good.... and yourf putting it on a mod anyway!
i would go with a 185mm juciy 5! £84.99 on CRC
just dont get a 160 though! its a waste of time <_<
I was gonna say - Is there any advantage in the Juicy 5 over the 7, apart from price?
