E.n.o Trials Freewheel
Trials mama
hey guys, me and mini man were jsut checking out our freewheels and realised that the outside blue seal is comming off and will not go back in. Is this a huge problem at all?? Mini man seems to think that his E.N.O skips when the seal is off/loose i can not back this up as i havnt ridden in yonks.
pwease help us
eddie and mini man
OK i can't help with the seal, but I'd check the chain before saying the freewheel is skipping. Alex davies (beastytrials) said his was skipping, but he was just running a really poor chain...
... :ermm: *awaits his critism
If the chain is fine, then it probably is the eno :P
The chain dosn't have anything to do with the freewheel skipping.
As for the blue seal, mine always used to stick out in one place, they are only there to keep the muck and grime out, won't effect the freewheels performance in the slightest.
(Y)
Thats brilliant thanks, panic over, lol ill let mini man no, as hes the only one who actualy has a rideab;e bike,lol
eddie
quite right but be careful you don't let too much grime, dirt dust etc into now that their is no seal as it will affect the freewheel mat cause skipping and the freewheel to clog up a bit
If you get an allen key tool with either a 2.5mm or 3mm (can't remember exact size) allen key on it, you can run the allen key's head around in the gap between body and shell and it seats the seal really well. Just make sure you aren't spinning the seal itself though. Worked for me, anyway.
The seal itself, unless it's somehow mashed into the spring/pawl setup at one point, won't affect the performance of the freewheel (until you ride through a bog or something).
(Y)
for alex it did, every time he thought the frewheel skipped his chain was tearing itself a new arsehole.
But then it had nothing to do with the freewheel. All i said was a chain can't effect the freewheels performance. :P
