Where To Get A Crank Extracter?
bikerboysam1
Listen to the lads that told you to get a park tool one (Y) I have used 3 or 4 diiferent crank ullers. And the park one does the job the Best, THe cheaper priced ones often rip the thread off of your crank arm (N)
Thats why you should only buy park too tools, They work ;)
Tom
Tom
A crank tool wouldn't do that unless the cranks are made of softer material than the puller itself, perhaps it was your cranks that was the problem or maybe you hadnt it set up right.
A mechanic shouldnt blame his tools....
Cranks are generally softer than the puller though :turned:
Yeh, you know I think you right. for example deore cranks are some alloy of some sort, most crank tools are steel, I guess it just depends on how tight the cranks are in the first place. If there not tight they'll come off fine, but if the BB axel has rusted and expanded you might have a chance of literally tearing the threads out of the crank....
That said, I had one of them park tool ones with the lever attached to it so no use for a spanner, it was seriously well made, very smooth movement on the threads etc.
Edited by jake1516
If its seriously tight and feels like your going to bust something if you go any further, hit the end of the puller with a hammer. Most of the knackered cranks ive seen have been put down to poor tools and too much force, a bit of shock treatment works wonders.
