Break Pads !
T-MAG-05-DAN
1) You put 'break pads' in the Topic title, and then 'brake pads' in the post
2) Try the search function
3) Don't use 'txt tlk'. Makes things so much harder to read for everyone else
4) Either: Plaz CRM, Koxx Blox brown, Heatsink blue or red
:)(Y)
Edited by Dan6061
I heard Rim Jam blues are really good but they come off their backings.
I use Palzmatic CRMs on the rear and find them wicked. On the front it is the Magura koolstops with slip for MEGA endos and front wheel tricks but i adjust the TPA if i need to use them for proper stuff.
hope i helped
HEATSINK REDS WITH CNC BACKING!!!
I would of said them.... if he had a grind but he doesn't.
My mate has some, when he first got them they weren't very good(he didn't have a grind), but after he had grinded hid rim they were really good.
Hi, in the dry weather the heatsink blues are just simply incrediable (Y) the new red compuond heatsink have go are supposed to be awsome in dry and wet weather conditions too, also koxx reds are amazing too (Y) but i have been using my heatsink blues at the moment and have been working a beast :D hope this helps. (Y)
