Freewheel Ont Front And Freewheel Ont Back
domonza
You can, but tell your Dad "Onzaboymark says it's shit."
EDIT: I suppose I'd better justify it. Basically, you're halving the engagement points. The front freewheel would have to engage, then pull the chain to take up the slack and move the rear sprocket, which would then engage the rear hub. This means sluggish, mushy engagement, and it will basically halve the engagement points. Theoretically, front freewheels keep the chain constantly taut (seriously, they don't), which would mean the freewheel would engage almost instantly, then engage the rear. You basically then end up with a highly explosive front fixed sprocket.
I worked it out one day that if you have an ACS and a pofile, you'd get effectivly 18ep.
What Onzaboymark said, shortened, is first one freewheel will have to engage, and then the other one.
you would have to wait 2ce the ammount of time for both of them to becombe engaged because with one fixed axis only 1 of them have to becombe engaged, if you have 2 engagment points 1 of them has to engage then rotate untill the other one becombes engaged and you can go forward
would feel supper mushy and shit it could work but it wouldnt work well enough for trials almost certainly
