A Few Stock Questions
The lemonade man
As I can't afford to buy another trials bike, I'm going to build up a stock from spare parts so I don't need to buy as much until I have money.
Anyway, just wondering a few things such as tyres. What widths would you suggest front and back? I'm thinking high rollers 2.5 rear and 2.35 front?
Wheels, what would it be like riding a frame designed for 26" with 24's? (planet-x zebdi)? Just always liked to try 24".
Flat bars or risers? Or are both generally used.
Thats it really, thanks alot.
the 26 inch frame has a geo for 26" wheels with 24" the bb will be tooo low
It won't. So long as the wheels are both the same size the bb should be in the same position height wise as it would if there was 26" wheels in there, its measured between the wheel axles remember :-
The bb will be a lot further away from the edge of the wheel than it would be with a 26" wheel in there so i don't know how thats going to affect it.
no think about it with 26" wheels the bb will sit like 13" above the ground if the b height was 0mm (monty urban etc)
with 24" it will be 13" above the ground so an inch closer which is 25 mm, therefore -25mm which isnt good.
you could always put stackers under your headtube.
a co worker at halfords when i was tere actually did that on a pdi'd bike :P
funniest thing ever lol, didnt tell him to see if he noticed . . .
:rolleyes: he didnt
ever
true story B)
well, actually, bb hight is measured from the floor, its just that us trials rider never really have a bb under axle level, so we just measure it from the axle.
If you put 24" wheels on a 26" frame, the bb WILL be closer to the floor, unless you put big 2.7" ballon tyres on.
I wouldnt really worry about it though, the only time it would matter if you were to put 24" wheels on a bike with an already really low bb (normal xc type bikes).
Ali is right! the bb will be an inch closer to the floor, be the 'bb rise' will still be the same because thats relative to the axles.
I personally would stick 26" wheels in it, because that what its designed for! It will ride ok with 24" (i know) but it won't feel anywhere as good as a proper 24" frame, leeson, curtis, ashton, etc...
