122.5mm Bottom Bracket - Will It Fit A Control?
giantwhore
pah, I used a 118mm bb with my control, that was with tensile cranks and 18 tooth bash, there was plenty of room.
That was with an 18t though Ali, u might squeeze a 20t in with a 118 but it would be VERY close try the 122.5 see how it goes.......
Adam
I ran a 113 on my pure - with a 22t middleburn set - no problems.
I cant remember what shell width the pure is but i had a raceface bb with the spacer on and it worked fine so im guessing with the control being similar down there a 122.5 should give you bags of room...
