Im A Noob And Need Help On Basically Everything .....
hi im a newbie 2 trials riding i got maself a mission reefer /connondale fatty r forks/truvtiv crank and bashguard new strong wheels and sum new magura hs33 i ride and oldskool 26 inch bike is dere ny tips u old skool riders culd give me ,i mean i can bunnyhop obviously and i can do about 10 bak hops but im tryn 2 learn 2 pedal hop ......ny tips :turned:
26 inch is not old skool i ride it and im only 16. all you have to do is get onto the back wheel as if you are doin a back hop and then to begin with jst give your pedals a little tap(a bit like a wheelie) learn to use your brake to stop you then once you have mastered that part try adding a little hop in aswell.
you should be hopping around in no time
He never said it was, he said he rode an old skool 26" bike. Old skool 26" bikes are ones with shorter wheelbases and slightly lower bb's etc. They have different geometry and are ridden in different ways.
Check out trialsride.com - walk throughs with photos and vids. They have a nice slowed down vid of someone double pedal kicking onto a 3 ft high rock.
Extreme sport's tips and tricks (if you live in the UK) has an episode where they cover pedal kicking/hopping -- keep checking, its on every now and again, they repeat often.
Cheers
Scazz
