Knackered Rims
Scooter
Echo 2007 Rim for the rear. I've seen those take some serious abuse and their fine. Mine should be here today or tommorow, definately go for one of them, on the front i use echo 06 rim, there fine for the front dont get one on the back though :P
Edited by Gaz M
(Y)
but an echo 05 rim for the front if you can find one.
if not then id say try all is the next best thing for it.
max.....
Edited by max-t
this is true, get a ronnie rim a put only one light grind on it, do not grind it more than once or they become realy weak and fold very easy, like mine is doing, personally i suugest what gaz says and get a echo 2007 keep 1 grind on it, plazmatic or zoo pads!
Edited by matt!
seen an echo 06 front rim turn into a pringle this saturday, he only nose dived off about 4ft and jumped off in mid air :mellow:
Funny how my ronnies had somehwere in the region of 30 grinds, guess one of us could be smoother than the other hey ;)
I run a front onza drilled hog disc rim, no problems *yet* but i would never drill a rim just to make it looks better or to loose say 50g becuase its not worth it you might as well cut down on your food portions if you want to loose weight.run a rear ronnie built on profile no problems, no grind using Heatsink blue pads and tar.
if you are knackering so many rims why don't you pump your tires up a bit so everytime your on back wheel you not *Riming* everything, that is how rims get Fook*d
Either way if you have a decent rim like everyone keeps saying get the echo 07, it will last much longer if you do pump tires up so you don' rim things.
Hope this (lecture) helps :P
EDIT: The drill walls of a hog rim is for show i guess, downside though, if my disc brakes or stops working i can't use a rim brake....
Edited by will17will17
