Help
oddies
Magura hydraulic brakes, they do different levels of brake but generally you are gonna struggle to find something to grab your rim tighter than these babies for the money.
(Y)
WHY? Why does every love f**king magura's? V-brakes are where its at. Avid ultimate, best rim brake out there, ask anyone that owns one, nothing compares to it.
few ones.pretty simple.
backwheeling-when you jump up to an object and land on it back wheel first
a grind-when the braking surface of the rim is made sharp by dragging an angle grinder across it.this improves the brake hold.
flex-when the bike frame flexes due to the power of the brakes.
pinch flat-usually caused by a harsh landing on an object and your tire goes down instantly.also known as a snake bite.
cant think of many really :-
premier-video editing program
ill edit when i think of some because i have no idea what you want to know
max.....
Edit: flat spot-when the wheel loses its roundness in a place.
water bleed-using water in your hydraulic brakes instead of oil.cheeper and more effective.
defect-when a part has cracked snapped or faded in colour.basically when something goes wrong.
Edited by max-t
