Brake Pads
fessey
Sorry forgot to mention im running a smooth rim and dont really fancy a grind as of yet, so basically what pads are best on a smooth grind.
Thanks
Fessey
I'm going from onza pads to the ZOO! hs33 pads for the rear (mono mini on front) off tarty. I'm running a smooth rim too. The pads arrived this morning so i'll fit them when i get in from work and let you know how i get on. Tarty link. (Y)
I Have a non ground rims and a hs33 for the back, a few weeks ago I bought my self some zoo pads and have so far been very impressed. They lock very well, they are a bit loud though.
Have a look at this " http://www.trials-forum.co.uk/forum/index....showtopic=41481 " (if you havent already) as it helped me when I was deciding what pads to get.
Cheers
well in my opinion i would say the zoo pads are amazing on a smooth rim. run a little bit of tar also on your rim and your brake will be imence. my mate has the zoo pads on the rear, on a smooth rim and a little bit of tar and it is amazing. If you are ever going to grind your rim then get a pair of plazmatic crm pads. I have been running them on my grounded rim for a while now and iv never had a problem. hope i helped you.
I have decided to go for the Zoo pads as my mate has got a pair of the older type with a fair bit meat on them so hopefully they will work better then my original magura pads.
Thanks for all the help
Fessy
hi, at the moment i am using standerd onza brake pads and i feel like a change. so i was wondering if anyone has any sergestions to any gd brake pads
thanks
fessey
hi mate it depends if you have a grind if u have a grind i recomend rim jams aparently they are the best but i dont no what pads without a grind :(
