Sutable Deralier ?
liam-pantera
Hi guys
recently after having wasted hours and hours and pints of blood because of my 74kings i have decided to go back to a derailer , so now i was wondering wich one would be most suited for trials .
i would also like to know if i should go with short cage or long , and also i dont have enough money for a rohlf tensioner so i need something with alota spring in it thanks guys :) .
im checking th abnk tomrow and i might purchase a rholf , and the sora is also in y mind the thing is ive tried every tensioner system going and only 1 type worked for me wich was the mech type . ive had the one arm pushdown type ive had the 74 kings and fixed dmr types and there all crap ive lost so mutch blood and skin because of those hahaha so anyway thanks everyone apretiate it (Y) .
Don't give up on tensioners just yet , especially if you don't intend to run any gears as a well set up tensioner is considerably lighter and more resistant to knocks than most derailleurs . Just realise that a tensioner will never work well out of the box , but with some careful adjstment to ensure it works with your choice of chain and sprocket , they can do wonders .
Get a short caged sram X-7 or 9.
better than shitmano as they dont bounce about like f**k as the spring system is totally different.
You are right about that si-man , ive tried the spring system on a sram x9 before and i quite liked it . Also if your main arm breaks off you can use the first cog as a tensioner just like neil tunnicliffe used to .
Checked my bank and im going to have to buy a rolhf and hope there as good as people say they are , thankyou to everyone that has replied and if the rolhf fails im going to buy a shimano sora super short mech .
