Can You Get 36 Hole Front 26" Rims In White?
NVWOCI WVS
im no trials expert but i havent seen or heard of any 36h rims like the try-all ones.did u realise its possibe to build a 32h rim onto a 36h hub?its done by missing a spoke hole on the hub every 1/4 of the way round.
steve
read my signature ;)
I'd rather not do that though, might just buy a new hubshell...it's to go on the back of my stock, want to save some weight, i spoke about it before and now i'm going to give it a go.
I know it's not going to be anywhere near as tough as a rear but i'll be careful on it and its for really streety stuff with reasonably high pressure (compared to what most of you use!)
there are these :-hello
there front and 36h, but require disc only!
ok, I'll explain this to you one more time:
what i want
*white rim
*single wall
*narrower front rim
*32 hole!!!
what you suggested
*yellow, black or mirror finish
*double wall heavy rim
*39mm width (Y)
*36 hole only
but thanks for posting :)
I'm sorry but at least he's tried to help. In the time its taken for you to write that out you probably could have looked a bit more yourself rather than just asking on here then slating people for trying to help you (even if its not so helpful).
So you want to put a front rim on the rear of the bike?
oooh look, 30 seconds on tartybikes and i found this: here
Edited by Krisboats
the title pretty much says it all...something like a try all style front rim in white would be cool, anything light and wide really! must be 36hole, which is where my problem starts!
what i want
*white rim
*single wall
*narrower front rim
*32 hole!!!
WHAT?!
