Screw On Chainrings...why?
tartan pixie
Is there any advantage of the isis system over 4 bolt with a splined bb? I run a race face crank/bb on my freeride bike (splined 4 bolt) and it works brilliantly so is there a good reason for people running chainrings that need a chain whip with scaffold pipe to remove?
3 weeks till i can afford my new bike, i'll give you some peace from the stupid q's after that. :unsure:
Smaller the sprocket, the better the engagement. And as Jon says, because you need chainring bolts, and they can only fit on a certain size, which limits them to 20t.
Screw-on sprockets have been around since the beginning. They are still used in track racing where there is a fixed engagement throughout (no freewheel at all).
screw in cog on fixed wheel bike = almost certain death
I don't understand. I have a track bike, which, as is standard, has a fixed screw on sprocket held in place with a lockring, reverse threaded. For reference, here it is.
you sir
ARE WRONG
Wrong about what. You can't just say that without offering some kind of insight into what is wrong, perhaps even helping the poster/me by telling me what you know that I don't.
as you pedal in one direction or another, it would unscrew itself
Well yeah, it would unscrew if you pedalled backwards, but unless you're a clown who works at a circus, I don't think you'd encounter that problem.
EDIT
Unless, as I've just been informed, you slowed down and forgot it wouldn't coast. You'd fall off, but also the sprocket would come undone.
Without alockring if you slowed your pedalling to slow the bike down, that'd gently unscrew the sprocket too. Had a go on a guy's fixie who's sponsored by Charge, was pretty good fun. He's got a smaller frame with low-ish rise riser bars on, and it felt really nice to mess about on. The stuff he can do on it is amazing, full-speed pedal grinds, 360 hops, etc.
