Frontwheel To Backwheel, How Is It Done?
Henrik Y
Hello!
When you jump onto a small obstacle and first land with the frontwheel and then swing the bike over to the backwheel on the same spot as the frontwheel was. How do you do it?
I've been trying this for a while now and it seems impossible for me. I've been training on flat ground and curb edges. But I only get the backwheel half way. If I let the bike go a little side ways it gets a little easier but still almost impossible.
Is there anything important that I should think of when doing this?
Round here we called that a smoke, as it's a damn sight quicker than saying "front to back".
At first, you'll end up almost swinging the back round, so the back wheel lands about 4ft from where your front wheel originally touched. At this stage in learning, it's pretty much a sidehop, as you'll find you take off quite sideways. Eventually, you'll be able to take off more straight on and be more accurate with it. The longer you wait on the front wheel, the more momentum you lose - so try and get the switch as fast as possible, and then it makes the straight on smoke a little easier.
There is a big risk of hitting the down tube, so practice on pallets to minimise bike damage.
You can practise just on the flat ground until you get the hang of it. Do an endo and then concentrate on smoothly letting the front brake off and pushing the bike so it sort of rolls smoothly through your legs. Don't have the back brake on at this point, only use it to catch yourself right at the last minute.
When you've got it nailed on the flat, move to walls which are, say, 3ft wide. Then 1ft, then rails ;)
The easiest way to explain I'd say is getting your hips right near the front of the bike as you land, as your back rises to above height of the wall lift the front and throw the bike forward as if your stretching when your doing pedal up/ bunny hop etc, this will push the bike from where it was straight forward under neath you. If your ass is near the wall when you land on the front as in very forward you will easily stick your back wheel to it.
How good is your front brake? The brakes on my last bike were very poor to bite when I pulled the lever, so I wasn't able to dump the bike nose first into anything without the brake slipping on me. On a freshly ground rim with trials brake pads there's more than enough hold to give confidence though. I've only been doing front wheel to back wheel stuff for a month or so and it was changing the brakes that made all the difference.
Edited by psycholist
I have a disc brake front. Not super but I think it's good enough.
But I will try a few new things that I didn't know before next time I ride and see how it goes.
Switch mayte. ;)
Just make sure you keep your body weight moving throughout the move. The bike goes from mobile to static to mobile again, but you need to keep mobile constantly. It's your body weight passing forward, nearer the front of your bike that keeps the momentum going in the move, and allows you to fling the bike forward.
Like over people have said, learn it on flat ground or a kerb, to get the motions down, then move onto something bigger.
People say rails is the hardest, it is in the sense of accuracy but once your wheel has switched (so your rear wheel is now on the rail), you don't have to hold on the rear wheel, you can just release the brake and kick the pedals.
Rather than switching on a large ledge, you have to hold it on the rear wheel to avoid the front end dropping (which on some ledges can be a big drop on the other side.
Personally, I consider a wheel swap to be a static move, where your front wheel is on the object and you are lunging to back wheel.
I've always called them switches or a wheel-switch. I'd call the other move wheelswap as its swapping from one wheel to another fluidly, rather than switching from one to the other. Though i guess the name wheelswap or wheelswitch could be applied to either manouvers. Static wheelswap and rolling wheelswap would be more accurate for the two different moves.
I've always found leaning over the bars and physically trying to flick the bars/front end forwards whilst performing the swap always helps fluidity and ease. Also keeping the back brake off helps the back wheel to roll into place rather than stopping it as soon as it hits the floor.
